Engine 85 CJ7, 258, Carb replacement
Gdamitbob
Maryland
85 CJ7, 258
I should have also noted the following:
-Fuel was coming out of the carb when the engine was running
-Fuel pump has not been replaced. fuel lines going to the rear have been replaced.
-Gas is possible bad, haven't had a chance to syphon. Can't tell how much is in there due to faulty gas gauge.
If fuel is being pushed into the carb while running that means the float valve is old and leaking. It (the carb) definitely needs to be rebuilt. The good thing it is pretty easy.
That's what I would do first. Most likely will fix the majority of your issues.
Also, you cannot make any tests with bad gas. Just take a gallon or two portable tank with an electric pump and bypass all your bad stuff.
Buy an $10 electric inline fuel pump, fill a gas can, and hook it to the carb. If that fixes the idle problem, then focus on the pump, clogged line, sending unit, bad gas, or rust in the tank. I wasted a lot of time and money rebuilding my TBI, only to find out it wasn't the problem. Good Luck!
Kinda what I said HERE.
Also, you cannot make any tests with bad gas. Just take a gallon or two portable tank with an electric pump and bypass all your bad stuff.,
I already have a carb rebuild kit so I can work on that. Is there somewhere I can find a step by step to using the electric pump and where to bypass? Unfortunately, I don't have much experience working on mechanical engines but I'm willing and eager to learn.
What an absolute great idea. Thanks for the pictures and post!
The access opening in the floor over the fuel tank with a small panel screwed over it was a no-brainer for me. Second CJ I did this on.
Fuel tank access panel in floor
I think we are moving away from your initial post.
Let's get the CJ running.
Rebuild the carb.
Use fresh gas.
Enough said...
Do you have an example of an inline fuel pump that would work for this application? I tried googling and I'm getting a ton of different things pop up.
If you google its expensive. Just use a gallon tank with a cheap auxiliary fuel pump and make your own.
I strongly urge you to buy a copy of the REAL Factory Service Manual MR-252.
$125.00
  62.5%
