85 CJ7 Tub hat channel
kanstiss85cj
Southwest Michigan
1985 CJ-7, 4.2L, T177, Dana 300
Hi all,
Has anyone here ever used 1"x2" tubing to replace sections of hat channel under their tub? My mid-mounts, where the roll bar mounts, all in that area are rusted out. Pretty common on a lot of CJ's. I do not want to spend the 50 a piece through classic enterprises for new ones. Suggestions?
Thanks in advance,
Kris
Hi all,
Thanks in advance,
Kris
:)Sure you can use square tube or any other metal. But, How well do you fab steel? 1x2 square tube will still cost you $3-$4 a foot, then your bending and fitting starts...........If you have good sheet metal on either side and can drill out the spot welds and replace it with a hat channel from classic @ $50 ea. will ..........."Time is Money". I also believe the original channel dimension wise is less than 1" inch.
Not trying to discourage you from honing your skills but there stuff requires minimal trimming and your installing & welding. I do a lot of fab work and there are just some things that your time is better spent at.
Just my opinion.
:D:D:D:D
Well actually, I have a good Fab shop at home. Anything from a Bridgeport to all Miller welding equipment. I am a student getting ready to start my senior year. My major is Welding Engineering lol. Im pretty decent. I was just curious about it. I have to replace the "foot" area of my floor pans anyway. As far as metal, I get it a little bit cheaper from a place back home. They sell me drop pieces for cash or will cut it for me. Either way, I was not going to replace the entire piece of channel. Just about the last foot or so where it goes back to the mid mount.
:)Well good for you, always nice to have equipment and the knowledge to use it.
Good luck on your project..........send us some photo's.
:D:D:D:D
I want to post a build thread as soon as I get home to build it lol. I am currently in Louisiana working for John Deere at their plant here. I am on my internship. 2 weeks left. I am ordering and buying things from here and getting everything together so when I get home I can start in on it.
I saw hat channel for 9.99 per piece on ebay, 2" wide by 3' long, said they would combine ship cost on up to 5 pieces at a time, also Quadratec has a 3 piece rear floor kit for apx. $25 plus ship...sometimes already cut is worth the few extra dollars.
Just bought some 2"x2" (1\8" wall) square tube from Metal Express, they had a local warhouse in my area, didnt charge to cut to my specs, worked well for my needs.
later, Ed:chug:
later, Ed:chug:
Where did you see that at? I have only seen the rear floor supports and not the outer supports under the driver seat.
  5.0%
