86 CJ7 fuel filler and vent tube
LASTCJ786
Mass
86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
I replaced the frame on my 86 CJ7 (YJ tube was last rebuild) This time I added a 1 1/4" body lift. I had to drop the rad. and drop the clutch bracket. Now I find the fuel fill and return are too short. It's a 20 gallon tank. Can I use a fill tube and return form another Jeep? The 15 gallen looks longer.
CJ8 filler & vent hoses are longer.
I would think you could cut them down to fit your application.
Looking at the 4WD book a CJ8 has a 1" fill My 86 CJ7 withy 20 gallon tank has a 1 1/4" inside diameter fill.
You must login or register to view hidden content on this page.
I've seen a lot of people cut the hose and put a short piece of plastic tube in with some hose clamps.
Yes I have heard that and may go that way.
$75.00
  37.5%
