'86 engine swap
Posi
Always Off-Roading Jeeper
- Media
- 172
- New England
- 54 Willys 3B, FI 401, T-18, ARB Locked, Hinkey Sidewinder Winch
I have a 86 CJ7 with 4.2L, T5, D300.
The jeep T-18 is far more expensive than the Ford T-18. I could be wrong though. When I was looking I already had the jeep T-18 and the transfer case. To go with a D300 I would have had to buy the transfer case and the adapter kit. So why spend the money on a jeep t-18 just to tear it apart when you'd do the same with a Ford T-18? I don't expect you to follow my logic on this one, but it makes sense to me.
Your situation doesn't relate to the PO.
The OP can buy the T-18 /20 and run with it as is, or
Install 315 gearing in the 20
Use the 300 he already has and adapted it to the T-18 .
Buy a ford T-18 and use his bell and 300
If the price is reasonable and it checks out fine I would go with the nutz to boltz Bell/T-18 /20/shafts. There are more fords then Jeep T18s out there, in my area they both can be had for the same price. I've paid nothing, to never more then $200 for a Jeep T-18 , the fords are going for the same price around here. I've done the Jeep T-18 to 300 swap, the 315 geared 20, and the ford to 300. All about the same price.
If he finds a ford T-18 he still has to buy the 300 adapter at over $500, the T-5 bell would work for him.
Or if the Jeep setup he is looking at is in good shape, and sells for a fair price, it's a plug n play no adapters needed.
