Build Thread A 1984 Black CJ7 Build - My never ending project/addiction
ok ok yes I'm still jealousYour Jeep still looks so good. You going to put the white stickers/paint on the "Jeep" on the front of the tub to match the tailgate?
As far as the tires go, I would recommend passing on the 35s since you only have a six and 4:10s. For me the power is a bit weak for climbing the higher altitude hills on the pavement. 33s are easier to handle also.
Nice looking rig! Any reason why you got rid of the spare tire carrier? Was it getting in the way?
BTW if your looking for a new project, you may want to consider welding in a full roll cage. It really improves the handling of the vehicle, and if you weld it to the frame, it's indestructible. It also looks bad ***!![]()
Thanks. The rear stock tire carrier is just not very good, especially with a heavy tire on there. The 33 barely fit. I just wanted a frame mounted tire carrier. Also, since I was getting the jeep re-painted, it made sense to remove it now. I probably won't have a tire carrier for a little while. I've spent way too much on parts recently and I don't need another hit to the account![]()
Sorry about that. One of your pictures looked like you maybe had a frame tire carrier on the back. You made the right call though. A tire that heavy riding on the tailgate, is probably not a good idea.
I lucked out that my PO installed a Warn frame tire carrier, and a full roll cage. I posted a pic of my CJ5 below. I probably wouldn't of been able to afford that stuff normally. Owning a Cj is like owning a boat sometimes. There's always a project to do, and it's always more expensive then you thought.![]()
The frame tire carrier really frees up the tailgate, which is nice getting my dog in and out.
Keep up the great work on the CJ!
Great looking CJ diddy2003! Just one question...with your current setup, do you get any rubbing? I'm about to start rebuilding my '84 and would like to run 35's...eventually![]()
