A little driveline angle help
Buuushman
Kihei, Hawaii
77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Now there's a cool demonstration on axle wrap. Makes me wish I could rig up a camera under my CJ to see what's going on down there. If you have ladder bars they have to allow the axle to manoeuvre. A single ladder-bar is good. Two is bad. I remember in the '80s when people would lift 4x4s sky high (some still think that's cool). They would use 2 ladder bars that would prevent articulation.
I am getting very slight vibration under hard acceleration, nothing when cruising or at high speed. The pinion angle seems to be a few deg. above a straight line with the drive shaft, I know it needs to be fixed but not sure how to go about it.
Even sitting still it looks like your pinion is too high. If there are shims at your rear leafs I would remove them.
Won't removing the shims increase the angle at the Transfer Case ? it's pretty steep already and the T-case drop is as far as I want to go. Can you get just the center section of a double cardan joint and use your existing flange/driveshaft end?
Thanks,
Bush
Thank you Dave, I appreciate your responses, but what I want to know is can you get just the center part of the double cardan joint and use your stock t.c. flange and driveshaft end to make it work or do you have to get the whole works from Tom Woods? The site wants you to buy a whole shaft and I am on a Limited budget, so if i can get just the center part that holds the two U-joints and shorten the shaft to make up for the extra length myself, I will go that way. If I just remove my shims, the angle at the Transfer Case will be too steep, and it will most likely bind. I do not believe it is axle wrap that is my problem, stock flat Y.J. springs lend themselves to that type of distortion, but the 2 1/2" lift springs that I have have enough positive arch that unless pinned solid, under heavy acceleration, they should not distort enough to bind the driveshaft. I can fabricate an anti-wrap bar if necessary, but I think it is driveshaft geometry that is the issue, and I want to know if there is a less expensive way to remedy this than taking $500 from my daughter's colledge fund for a custom shaft.
Many Mahalos,
Bush
Bush, I got my driveshaft for $334 including the flange for the TCase. I don't know if Tom Wood would sell you just the CV Joint. I doubt it but you could ask.
You should be able to buy the double joint. If not a trip to the junk yard should get you one. Alot of guys get the front shaft out of the mid to late 90's ford explorer and shorten it. it has a double joint on it already.:chug:
Thanks Old Dog, that's what I was looking for. I know the guy at the local wrecking yard and I'm pretty sure they have a pile of exploders over there, so grabbing a shaft and chopping it sounds like a plan.
Mahalo,
Bush
