A little driveline angle help
Buuushman
- Media
- 7
- Kihei, Hawaii
- 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Compared to the diagrams of the way it should be, my drive shaft angles are all goofed up. Got some crappy pics from my phone- drive shaft to Transfer Case , drive shaft to diff., and homebrew -Transfer Case drop. There are degree shims in the rear spring pack and the Transfer Case drop is about 2". The drive shaft is 16 1/2" long and I am getting very slight vibration under hard acceleration, nothing when cruising or at high speed. The pinion angle seems to be a few deg. above a straight line with the drive shaft, I know it needs to be fixed but not sure how to go about it.
Thanks,
Bush
Thanks,
Bush
