After a small body lift, two clutch related questions
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I was forced to do a small body lift on my Jeep (about 5/8") to make things align properly. Which created a clutch issue. I have a mechanical clutch on my Jeep where the bell crank is on the frame. Naturally with the lift the clutch rod from the pedal to the crank is now to short to properly adjust the clutch action. I beleive I have an idea on how to lengthen the rod, but knowing the variety of methods possible I thought it would be good to throw the question up on the board.
- So, what method would you use to lengthen the clutch rod?
- This almost embarasses me to ask. How do you adjust the rod as it relates to the bell crank? Right now my clutch is almost impossible to operate correctly with all the clutch engagement coming at the VERY top of the pedal. I need to find a way to lengthen the engagement length and move it further down the pedal throw.
