Aftermarket intake issue
Flowery Branch GA
1980 CJ7, mostly stock 258/T176/D300
More than likely the manifold's surface is not flat. To check this the manifold needs to be off. Then with a straight edge, Like a metal square, check to see if it is flat all the way across. If it isn't, it'll have to be machined. If it is, then you may have tightened the bolts in such a way that it is bending that side. Did you buy this new or used? If used, that may be why it was for sale.
