Almost died
Almost died
Germy
Full Time Jeeper
Cincinnati, Ohio
1971 dodge dart built 318
Sway bar disconnect busted at around 45 mph. The :dung: hit the fan, the tires were bouncing and i just slammed on the brakes. I was thinking axle. But the disconnect is gone
Glad youre ok. How much damage to the CJ and what caused the failure?
Sway bar disconnect busted at around 45 mph. The poopie hit the fan, the tires were bouncing and i just slammed on the brakes. I was thinking axle. But the disconnect is gone
Holy :censored: , I am glad to hear you are ok. Let us know what caused it.
I disconnected with old dog(this problem has nothing to do with old dog) to work on the front end. The pin was aluminum and corroded as are the disconnects. I just forced things and this is the result. Ill get some pics. I dont think any damage was done. Just sits lower on that side. Any suggestions on disconnects that are superman strong
Would an aftermarket 1 1/8 sway and new disconnects make a good difference or should I stay stock on sway bar and just replace the disconnects
Sent from my iPad using Tapatalk HD
Glad you got it shut down, that can be scary times there! I would be mor concerned with matching the fabric in the seat plug that was missing than what happened for a few mins anyway...:chug:
Haha!!! It was an oh sh** moment for sure.
Did you ruin your seats?
Also ordered a demon 650 and 1 inch plenum.
:eek: Good to hear your ok.
I don't want to loose my coffee connection :D
Thanks for caring, about coffee.
Found cause of failure. While replacing u bolts and shims, I did not re check them since. They had worked loose on the opposite side of failure. Wedge was freely moving
When installing new sway bar end links, i have a question. Now that the disconnects are gone, i can actually compress the springs. Is it possible that the end links were too long and the weight was on the sway bar? My new ones are adjustable. How do i know the proper length adjustment with a 4 inch lift
Sounds to me like they are to long. I wonder if the PO bought the wrong ones.
I have not run a sway bar on my Jeep CJ7 for years. It has never been a problem.
Glad you are ok..!
I think the problem was me running very loose u bolts and the :dung: hit the fan. Disconnect i think just couldnt handle force and the pin sheared.
You guys running no sway bar, any cornering or driving issues on road?
I haven't had any issues with not using my sway bar, I also have a 4" lift from Superlift, which is already fairly stiff.. but no, no issues here.
Mine drives ok without one with my 4" lift springs, but I might feel different if I had to turn real fast to miss something.
My jeep CJ5 did not have a sway bar. I ran it like that for 13 years before i installed one. No issues
