amc 20 axle problems
mikeydof3
jersey shore nj
1983 jeep CJ-7 4x4 253 6 cylinder
hello all new to forum so last time had axle bearings replaced I was told and saw that the housing was worn where the bearing fits in on the axle shaft to the axle housing so the race of the bearing is/was not tight in the housing any ideas on a fix?
Try to post pictures. If it is the housing that is worn, you might have to think about another AMC20 axle. I would look into 1 piece axles also.
I would think a Mickey Mouse repair would be to try and install the bearings with steel shim stock around the bearings which comes in thicknesses in .001 increments.
T'head-Won't work-BTDT;)
Are these the POS/OEM 2 piece type axles?
If so-DUMP'EM and get some Moser 1 piece.
The race can be set with stud and bearing mount Loctite.
