AMC 20 bearing preload
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
What do you do if you can not get enough preload. I am installing a one piece axle And on one side I can not get enough pre load. I cleaned all the por of the axle housing flange and still come out with only 3 thou of the bearing past the housing. The other side is fine.:bang:
You might try to get some bearing shims from a bearing supply store.
