AMC 304 Oil Pressure Issue
I don't see a loose wrist pin going away after warm-up?
I have-
One way to maybe find the cyl where this is.
Pull, one at a time and replace-A spark plug wire and see how much worst the knock gets.
Old fart way to find'n a bad con-rod bearing.
Did that already. No change noted.And, YES, I AM an 'Old Fart'!
?)Hey Span24, I had a similar problem.. What I finally resolved was weak valve springs and oil residue! The previous owner had obviously used an oil that was high in paraffin. Some oil companies use it to raise viscosity, but it leaves a brown residue in the lifter bores (slowing the lifter speed).. If your dipstick has a brown residue on it, be suspect.. Also with any "heat" event, the valve springs weaken.. Then you'll have a "loss of contact" problem, hence the tapping.. I changed my valve springs,, was NOT costly at all, and it made it rev much better.. No more tapping.. I even changed the valve seals while at it.. After plug/rocker removal, just "float" the valves with a compression test hose hooked to an air source, (after hose valve removed), bump the edge of the valve retainer tops, compress tops with lever remover.. ect.. took about two hours..![]()
