AMC 401 or AMC 360: Newbie install first engine swap
Bueller?
The 401 is missing all brackets and the price is significantly more. I'm leaning toward the 360.
I would get the 401 and source the brackets... To answer your question, yes I BELIEVE all the brackets for 401 and 360 accessories will be the same.
Not 100% on that, but around 99% sure.
~ Jr
Yes.. AFAIK all the brackets are the same between the AMC 304 ,360 and 401. headers are the same, intakes can be the same but you really want to have a 4bl for the 401.
Whats the quote from the machine shop? My local guy says between $AMC 150 -$200 per cylinder. Also look into the oil system upgrades.. Try to find a shop that has a good amount of knowledge on AMC motors.
I am getting ready to put a 401 in my 80 CJ and convert it to an automatic from a 4 speed manual. I will be watching your thread and learning.
Sounds like a great setup. Hope you Lso put a build thread together so I can follow.
