Another speedometer gear question
OEM1984CJ7
I have read just about every archive on the speedo gears and cannot find the answer. I have the 1984 CJ7 with stock 2.73 axles running 30 x 9.50 tires that are 29.5 diameter. I originally had the Dana 300 that had the three different positions speedo housing on the 26-31 setting and a red 26 tooth gear. I bought another D300 to swap it with due to bad/hard shifting and this dana 300 has the speedo housing with the 21/25 on it and there is a 25 tooth yellow gear in it.
The two gears are different size and tooth spacing and do not look interchangable. I am trying to find out what was factory with the 215/75 tires and get it close with my 30 x 9.50's. I cannot find any tooth gear chart with 2.73 axle gears on it. Help please.
What should be stock? Both?
