axle swap concerns please help
knp6212
- Elkhart, IN
- 85 CJ-7 4.3 chevy v6 with 5 speed and stock t-case and factory dana 30 front and amc 20 rear axles
im working on puting a small block chevy in my CJ7 , with the lift and body mods im doing i plan to run hopefully 37's but my question is what are some good budget axles i can swap in that will handle the extra power and rubber but not break the bank..?
I have the same setup and luv it. Did you change the camber to positive 5-7 degrees?
