Backspacing???
Backspacing???
plumcrazy
Springville, Pa.
'79 CJ5, '83 DJ5, '04 Silverado
I wondered if someone could explain what "backspace" is when refering to wheels? I have 10" wide wagon wheels on my CJ and I like the look, it gives it a "wider" look. I want to upgrade to an newer aluminum wheel and stick with the 10". What would be the prefered backspacing I should look for and where is it measured from? A friend has 8" wheels on his CJ and used wheel spacers to give it the wider look. I know some of you don't like the spacers, I'm not a big fan either.
man thats good....also remember that the wider and taller the tire the more chance you have of rubbing the frame and inner fender at full turn.....if you are changing tire height and width you might ought consider doing a mock up to get a sneak peak at what you might get. I have seen guys use sticks and coat hangers to replacate the height and width of a tire and use it to check for fender clearance issues
$150.00
  75.0%
