Ball joint adjustment sleeve
tinman
Idaho Falls
81 CJ7, I6, T5, D300, 4.2 block with a 4.0 head, Cherokee MPFI
FSM - Tighten the lower balljoint to 70-90. Then tighten upper ball stud seat to 50 ft/lbs.
I broke a cheap socket before hitting 50. Picked up a good made in USAand worked fine. Silly me for not noticing "China" on the socket.
Was the steering knuckle installed when you tightened the adjustment sleeve?
I would say yes, you should be able to reuse the old sleve.
Ok, I'm back, been installing floor tile at the in-laws house all weekend...something I would NOT want to do for a living!
It looks like the old sleeve when torqued to 50, is pretty much in the same place. Everything seemed to go back together pretty well, but this is my first time doing ball joints, so hopefully it all works out
Is there some way to tell if the amount of pressure it takes to turn the steering knuckle is right?
