BBD Vacuum Piston Gap Adjustment
MDJEEPER
Calvert County, Southern Maryland
1986 Jeep CJ
Mostly stock, 258 c.i.d., T-176 tranny, Dana 30 front, AMC 20 rear, Dana 300 t-case, 31x10.50 tires, 2 inch body lift
Guys,
I'm trying to adjust the vacuum piston gap on my BBD (at least until I dump or rebuild the carb). The fsm says the gap is supposed to be .035. To measure this gap, I am inserting little ignition feelers under the silver tang as far as I can get them. However, no matter how far I adjust the set screw, the feelers I'm using remain sloppy loose in the gap. So, I am obviously doing something wrong.
What's the secret to measuring the gap correctly? Am I even measuring the right place?? :wtf:
It's a bitch. You are looking for a small air gap between the upper and lower tangs. .035 is correct.May the force be with you.
Thanks! Any specific tips at all to get that measurement somewhere near accurate??
    Best for votes
    on specific items
