Bed liner
Bed liner
1955 Gillespie 23070 OD from Midwesy Military. It's great for touch up on the trail :)
I'm going to try a rubberized undercoat in a spray can. It looks pretty good and will be easy to touch up.
I think I am going to use a marine deck paint, it is urethane based, and non skid, the PO drilled allot of holes in the body and I figured I would epoxy the holes for strength and rust resistance, then with this coating or other similar "thick coating, it would hide the little things like me tub having up to 1.5" holes drilled all over the place. The stuff I am buying if $30 a quart, so I figure two qts should be good. It should be easy to touch up as my buddy did his CJ5 and he used just under a quart but his is fiberglass, and looking at it there are allot less "nooks and crannies" to get into, and this stuff can be sprayed on.
