Belizean’s after retirement excursions - took 40 years after buying my Jeep CJ7 off the truck.
Yeah I’m still considering that option if needed. I’ve never seen one before like yours that far down stream. I thought Holley recommendation was around 8” .
I have headers mine 6-8" past the collector
I put this thread aside to read awhile ago cause I wanted it to build up. So glad I did. Sitting in the tent at camp getting rained on was the perfect time to sit back and read this. Definitely an enjoyable read
Use a spark plug washer on that sensor.
Add a dab of copper anti-seize on the threads.
Hey Lumpy. Glad you are still hanging around. Actually if you take a good look at the pictures of the sensor you can see it has a washer. My buddy who’s a master mechanic told me specifically not to use that cooper a s on the treads of that sensor. :chug:
It’s been raining a lot every day around here. Was finally able to take a nice ride this evening and I think the sensor is still working well. So hopefully I’m good to go.
I used high heat copper anti seize on everything. In fact I'm pretty sure new Bosch units come with it already on the threads
Even Autolite said don’t use on their spark plugs. My Bosch when new, I didn’t see anything on the threads.
It's under that clear cap typically it's grey in color
Information for all: If you paste a link to the actual post on a line by its self, an unfureled link will be created. You don't have to create a screen shot if you do not want to.
link example = https://jeep-cj.com/community/threads/teamrush-ignition-upgrade.11416/page-9#post-269524
Some manufacturers, like NGK, say that anti-seize is unnecessary and can be harmful. Others, like Bosch, recommend using a small amount of anti-seize at the base of the spark plug. If you do use anti-seize, you should apply it sparingly. Too much anti-seize can cause the plugs to stick in the cylinder, or it can foul the plug and lead to carbon buildup on the threads. Metallic-based anti-seize compounds can also spatter onto the insulator tip and cause misfires.
Really depends on your manufacturer. I tend to only use Bosch and AC Delco. I also don't gob it on really just a tiny bit on first few threads.
Glad you read the above, that’s what it explained, plus the threads and torque distortion problems.
Your buddy is mistaken.
You want the anti-seize. It helps with electrical contact and removal.
Same for spark plugs.
Can you bevel the opening some to clear the hex fittings of the sensor?
You must have missed my post with picture. O2 sensor seated and tightened down with that socket. Fixed I believe. I don’t need the anti seize for plugs or O2 sensor. I do use it in other areas on the Jeep
I only used anti seize on one spark plug. The plug closest to the firewall on an L-Head. Those that own them know.
