Bell housing Interchangeability
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Can I use my T-5 bell housing with the T 176?
Sent from my iPhone using Tapatalk 2
The T-5 , T-4 and SR4 use the same one. The T-176 is unfortunately in your case different. The mounting holes wont alighn.
Can I use my T5 bell housing with the T 176?
Inside the aluminum bellhousing, there are locations for another hole pattern. These locations can be drilled and tapped out. This is what I did to make the bellhousing in my '86 accept a T-18 , i'm pretty sure that the T-176 and T-18 take the same bolt pattern. There are writeups in the Advance Adapters catalog about this.
Ok, so I need a T-150 or T-176 bell housing. I can get a T-176 tranny for AMC 150 so I am looking to find a bell housing for it.
