Trans Bellhousing Replacement
HossPete
Nashville
'78 CJ7, Golden Eagle,. 304 V8, T150, D20
When I removed mine prior to the engine/tranny swap, I removed skid plate, removed the drive shafts, removed the tunnel cover inside the Jeep, removed the shifters, used a low profile floor jack and a piece of plywood under the tranny/x-fer case, unbolted the bell housing from the back of the engine, slid the assembly back enough to clear the shaft, and lowered it all down. I did have to reach the top bell housing bolts from under the hood rather than from underneath the vehicle. Actually easier than I expected. When I installed the new GM V8 and auto Transmission , same process in reverse. I installed the engine, bolted on the torque converter, and then used the jack and plywood to raise up and install the trans and x-fer case pre-assembled together as a unit. I have a 4" spring lift and 35" tires, so no ground clearance issues. But if I had a lift, it would have been even easier.
