bent push rod question, or two
spikey
Portland, oregon
1978 CJ-7
Have checked the valve to make sure it's not seized?
I replaced the bent rod and put the rocker arms back on, then turned the crank by hand till I saw the rocker arms move. If that's what you mean? Although now that I'm thinking about it it started raining pretty good so I closed up and came in for the night. I didn't get to see the one on the right move. I'm guessing it should move fairly close in time to the other tho?
It should move about one revolution of the motor from the other pushrod of the same cylinder.
thank you for that. Just got home from work and turned it by hand. The one on the right only moves half as much as the one on the left. if even that much. I'm guessing it's time to pull the intake?
I think the rocker mounts on a pivot ball and it is designed to have some play in it. The hydraulic lifter will make up this difference once you start it and get some oil in there. However, you could have a collapsed lifter as part of the strain on the valvetrain which bent the pushrod. I would be suspect of the valve also since it apparently kissed the piston.
Did you use rebuilt heads? When you grind the valve seats, the valve sits deeper into the head, which causes the rocker arm to hold the push rod lower. If you use a rebuilt head you need shorter pushrods or rocker arm bridge shims.
I personally haven't touched the inside of the motor, aside from putting in a new timing chain. From what I got it if the po when I bought it, was that he had put in a comp cams cam and lifter lifter set. He threw in a 360 with the jeep cause he was going to build that. So as far as I know it was never rebuilt. There is a serial number on the push rod, so I could Google it and see what it says
I still think the problem is in the valve either its sticking or bent I would start there. IMO
There isn't enough information to be definitive...but here's the basic scoop.
The non-adjustable valve train on the AMC motors is, by nature noisy and loose. There is about .020 difference between the shortest and longest pushrod in any given stock motor. A failed lifter, a loose rocker hold-down bolt, or a bad cam lobe can cause the pushrod to get cocked and bounce until it catches on the edge of the lifter or the rocker arm lip...then Pow! it bends!
So, since you put a new rod back in, do the following:
1. Loosen all spark plugs and remove/examine the affected plug NOW
If the plug looks undamaged
2. rotate crank by hand (wrench) SLOWLY
3. check for the rocker/valves to open/close
If everything seems to work...
4. replace/tighten the plugs
5. do a compression check on the bad cylinder and two others
If that checks pretty OK (+ or - 15 lbs.) (@ near to 130 lbs.), then the piston is good...
6. do a leak-down test(see how long that cylinder will hold compression compared to another cylinder).
If the cylinder will hold within 10 lbs. for 2-3seconds compared to another, then your valve is undamaged
7. Now you have to check the cam lobe and maybe the lifter. Get a dial indicator or rig up some way to accurately measure how far the valve stem moves when you hand rotate the crank...do this for the affected rod and any other similar valve (intake/intake, or exhaust/exhaust)...the reading should be within about .005 - .008 if your lobe is still good.
At this point you can find a slightly longer pushrod (like from an Olds V-8) which is what I use to compensate for wear over time, or tear down to the lifter if the motor won't idle properly. BUT, IF you need to go after the lifter...I would consider a valve job. That of course depends upon your motor mileage...you'll be out about $300 - 500 depending on your skill level, so a whole rebuild isn't out of the question.
Oh yea...must have not seen the latest...sorry to hear the lobes were toasted...PAY ATTENTION...USE MOBIL 1 TURBO TRUCK or HIGH MILEAGE OIL...Flat Tappet cams NEED ZINC PHOSPHATE (ZDDP)TO RUN WITHOUT WEARING. Look for a C4 or SL rating on your oil of choice..New cars do not need it due to changes in spring pressure and new oils don't have enough for older motors!!!
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf Please go here to see what I mean.
Gutthans there's some great info there thank you. Just a touch too late. lol
The really sad thing here is since the first timing chain had to be replaced a year and a half ago I had a friend telling me I had my cam going flat. But he's one of those "know it all" types so I blew him off. I knew that I've only had this cj 3 years, and the cam was put in about 2-3 years before I bought it. lesson learned.
    Best for votes
    on specific items
