BEST in tank fuel pump and sender for GM TBI on cj7 jeep!
76cj7chick
Old Time Jeeper
WA
1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Howdy all!
I've upgraded my carb to a GM TBI system... And would prefer the in tank pump assembly...
I've heard Novak makes one... But am kindof strapped for cash... I am willing to pay up to $140 ish for the assembly or convert my current fuel sending unit to a fuel pump assembly?
Although I have a 76 CJ7 ---I installed a plastic 78-86 CJ7 jeep tank from MTS 15gal part # 0051...
Would it be easy and wise to convert my current sending unit to an electric fuel pump assembly? If yes, anyone have pictures of this process? :rolleyes: ---I'm thinking of using a fuel pump rated for 12-15psi, like E3902... But not certain if it will work properly as I don't have a bracket to hold it in place...
Just concerned about wiring... Do I need to drill a hole in the top or can I connect the pump power to the sender connector... Then there is the ground wire for the pump..
IF ANYONE HAS BEEN SUCCESSFUL IN THIS MOD PLEAAAAAAAAASE UPLOAD PICS AND INSTRUCTIONS!:drool:
OR
Get the Sender unit from Novak and install a lower psi fuel pump in it?
OR
Some people say that the sender for a yj 2.5l tank will work in CJ7 ... BUT I contacted MTS and they said that their YJSU-1P unit measures 9.5" long and top plate is the standard 3.5"
My CJ7 fuel tank has a 2" opening/hole...
PLEASE HELP! NEED TO DRIVE MY HEEP!!!! :notworthy::notworthy::notworthy:
Re: BEST in tank fuel pump and sender for GM TBI on cj7 jeep?
Nobody?!?!!?:confused:
Guess I have to go with an in-line pump.. :rolleyes:
I want to mount it on the driverside of the frame... Anyone have experience with this that would like to share with me on how and where they put the pump?
(I originally had the pump and filter on the passenger side ALL the way on the tranny skid plate.. Problem with that was SOOOOO far from the tank...
Hope to hear from someone who has experience with this Fuel injection mod. :o
I have no experience with your upgrade but I know when installing a electric fuel pump you want it as close to the tank as possable and low enough that the gas as a siphon to the pump so all it has to do is push it to ths engine. So I would think on the frame rail just in front of the tank would be best. I hope this helps some.
I have an inline pump with the Howell tbi kit and it has worked pretty good for the last ten years or so, it even passes the Ca. smog check. The pump is mounted on the passenger side frame rail next to the Transfer Case . I was recommended to use the Airtex E8094 pump and I keep the pump supplied with the tbi kit in the Jeeps toolbox. I like to run 9-10 psi for fuel pressure. I would think it could be risky going off camber with just a few gallons in the tank, so I try to keep it as full as possible.
Hi Mtnwhlr! Thanks for your comment. ;)
YES! If I can't get it to stay cool (since it will be near the hot exhaust) I will definitely pm you! :notworthy:
All you would need to do is mount a heat shield between them.
Those are some pretty impressive in tank pump setups. I gotta ask this though, a properly set up pump should not have to be replaced at all, so I think there is a problem somewhere. I notice that Hack seems to place the filter on the outlet side of the pump leaving it vulnerable to damage from contaminents in the fuel tank. Also for those guys running electric fuel pumps, just how are they working for you? In my opinion, a tbi pump does not have to be one of those high pressure jobs that use a lot of amps and send most of the fuel back thru the return line anyway. For the in line pumps there seems to be two different ways to install them, one being close to the tank allowing the pump to suck up the fuel then push it out, or installing it midway at a low point and allowing it to siphon from the tank to the pump.
Thanks for getting back with me on that Hack, I wasn't sure of the type of fi unit that you had. As I recall only Ford tried an inline/exterior fuel once then quit using it. Actually I did have an in tank pump die on me once but it was covered by warranty, I have also swapped electric pumps on my CJ on a busy freeway but the problem was a bad icm. I have now setup my pump as close as I can for a quick change operation. I am quite surprised to see you getting 40 psi on an inline pump and having it work well. Your previous experiences with in tank pumps do sound quite expensive also. It is nice to hear from a fellow Jeeper having success with an inline pump, if I have any issues, I will move the pump closer to the fuel tank. Running with my current system I was able to get my fuel tank down to 3 gals with no issues. I hope this provides some useful info for the op.
Holley Blue or Red label. Best for your money and you can't take enough fuel from em.
Thanks everyone for your responses and lots of good pictures too!
I've since modified a oem CJ7 fuel sending unit with a gm 12-15 psi electric fuel pump... Let me know what you think! Also, Can anyone verify what the OHMS are supposed to be between the ELECTRIC FUEL PUMP POWER WIRE AND GROUND?!?! (Just wondering since I modified a "special" hole for the power wire to feed through and put some nylon flat washers in-between the hole along with a rubber gasket-from the previous fuel sender unit...) DON'T need the Fuel tank To EXPLODE on me...:eek:
THANKS AGAIN FOR YOUR HELP!!! :chug:
Again, if you know what the ohm reading is supposed to be in regards to the ELECTRIC FUEL PUMP POWER WIRE to the sending unit.. I would really appreciate your help...
I am not really sure of what you are talking about, as there should not be any conductivity from the fuel pump power wire to the sending unit as they are entirely two different circuts. Hopefully your connections are secure and well insulated at the pump, as there is probably some conductivity in gasoline which would create a minor short from that power line to a ground. I would think you have done lots of research from other postings of people who have created these units.
hi torxhead!
thanks for your response... urr... to respond to your question.
to clarify: i don't have the sending unit wire connected to the electric fuel pump power wire.
i drilled a separate hole in the top of the sending unit and installed a a small bolt, the electric power wire, then a nylon washer, then a rubber shoulder grommet... and then another rubber seal and nylon washer, nut then the connector for the electric power feed. (i didn't touch the sending unit wire or connector. it is still on the stock feed.)
so my concern/question is this:
if i use a ohm meter to measure the resistance or ohms to the electric fuel pump and ground --what should i get?
i know that the electric power wire isn't supposed to touch the metal fuel sending unit plate, but how many grommets/shoulder washers/nylon washers would be good to keep it from grounding out?
me scared.... :o
