best tires ever???
best tires ever???
I was thinking the transmission would be the first to crater. :cool:
any body want to start a pool??:laugh:
X2 on that!"Never give a slushbox an even break!":eek:
Correction, that's a Dana 30 front Dana 35 rear. Be ready to kiss those babies Bye Bye if you start spinning a set of 36"X12.50 "Super Swamper TSX's". I would definitely upgrade my driveline before doing any hardcore mudding, or prepare to have someone with a winch & trailer to get you home.
You might not arrive a trailer queen, but that's the way you will leave.:eek:
:censored::censored::censored:
a full floater?
Your D35 rear is a "Semi Floating Axle" most D60's are "Full Floaters".
Meaning that the axle axle is floating or not supporting the weight of the vehicle the housing is.:cool:
would you meet me in the chat room longhorn?
pleasssssseeeeeeeee
apparently so how does one do this floating axle?
That falls under the adage"Real Jeeps are Built not bought".
You have to find a good one under a 3/4 or 1 ton truck & fit it to your rig.
You would probably be better served to go with a smaller tire now & save your money to make it better when you break it
how would 33x12.5 look on a 8.5 lift? or 5inch lift? i just need to know how high imma sit
You need to lose the body lift. You'll be all right then.;)
yeah i was thinkin about droping the body thn puttin the blocks under the perches so i can reuse the bolts, old bolts were thrown away, we were all ambitious at on point right?, i still am lol
i can get mud kings for 175 there 35x12.5xr15 would that work with a 5inc lift? and not total my axles cause there light?
The "Mud King" idea sounds OK, but Iwoukd advise against using the long
bolts. Bolts are cheap. I would buy good quality grade 5 or better bolts, washers & nuts.;)
well the mk's are 175 a pop verses 300 for them SS, what are better tires around that price? besides the smaller ss witch are like 230 a pop
Like I said I'm fine with the "Mud King" tires.
scale 1-10? 1 a slick 10 sick tractor tires
what would you rate the super swamper SLT radial?
