Blue cj5
Blue cj5
Blue cj5
Texas
1981 cj5 327 small block bor30 over 3/4 cam with 4 barrel chevy m trans. Solid Street axles.373 gear rear end.
cant figure out how to send anything on here:mad:
What are you trying to send? So I can help you.
wounder if anyone can help me out when i climb a bank 75 degrees or more i lose fuel pressure. happens with full tank of gas or quarter tank same thing every time:notworthy:
Sounds like the floats in the carb. Most street carbs do not work at such angles. Solution is fuel injection. Holy Truck Avenger carb is an improvement, but may still starve of gas at such angles. Rod
