Body mount spacers
Body mount spacers
Duhwhat
Madison, Ms
1986 CJ7 2.5L 4 cylinder
T-4, Dana 300, AMC 20 rear end
I bought the CJ7 mount kit and assumed there would be some info with them explaining which spacers went where if there were any differences. Well, the bag had 12 spacers the same size, 12 metal sleeves that fit snugly in them and two larger pucks with holes too big for the metal sleeves. This has me confused..... This must be a universal kit that also fits CJ8 's.. Are all the spacings between the body and the frame on the CJ7 the same?
Ps there are also the twelve underside smaller spacers..
It's the bigger ones that have me scratching my head thinking they go somewhere and I'm not sure where
They should be for the front grill. There is one large bolt that connects the grill to the frame in the bottom center.
So as far as you know, the spacing between the tub and the chassis should be the same on all the mounting points excluding the grill..
yes. spacers should be all the same length. Like CJ said big bolt goes under the grill
