Body mount
Um, good job?!? What are you asking?
Just replaced body mount bushings on my '86 CJ7. Felt like the front one under the grill bottomed out before getting tight. Thoughts?
There is one bushing between the grill and frame. There should also be another under the grill between the frame and bolt/washer itself. Are both there?
^^. What he said... If so were they the same size as original replaced ones? May just have to get new bolt... Just did this with mine replaced with all grade 8 all the way around the jeep, point is they are commonly replaced with different bolts...
