Brake Bleeding - Proportioning Valve
CDT540
Austin TX
1983 CJ7
258, 5 spd
I need to bleed the brakes on a '83 CJ7 I just purchsed. My repair manual says to use special tool "XXXX" on the proportion valve before attempting to bleed. Well of course I do not have that tool nor does the manual say what the tool does so I don't know how to create a work around. I see on the end of the valve here is a rubber cover over what appears to be a plunger of some sort. Would someone give the 123s on how to address this and get my brakes bleed.
Thanks,
Chris
'83 CJ7 AMC 258 i6 / 4.2l -4spd
Austin, TX
I have bleed many things over the years and have never bleed the proportioning valve or know why you would need to. That said if it was me I would just bleed the brakes and not worry about it. Maybe someone smarter than me will chime in with why you would need to do this I would love to hear why.
http://www.restockit.com/proportioning-valve-depressor-for-abs-brake-systems-%28otc7853%29.html?source=IDx20111014x00001g&utm_source=IDx20111014x00001g&utm_medium=paid&utm_campaign=comparison&utm_term=DynamicPropertyName_SKU&bvar10=googlepla&ci_src=17588969&ci_sku=OTC7853&kw={keyword}&adtype=pla
this little gizmo clips onto the little button on the prop valve. Or you can have a friend push it in with a screw driver. I am not going to voice an opinion on the usefulness of this tool but if the manual thinks it's a good idea they may know what they are talking about.
From what I understand it negates the bias and allows equal flow to front and back but that's just something I read someplace.:cool:
I diregarded the proportion valve and bleed as usual with the Mityvac and it went fine. Thanks for the feedback...
