brake booster bracket
80CJ6
- Colorado Springs, Colorado
- 1980 CJ6 (built for export to Panama) Small block Chevy stroker (383) Turbo 350 with trans-go kit and B&M shifter, Dana 300 xfer, Ford 9inch axles on both ends,4.10 gears with a Detroit locker in back/power lock in front. 35 inch Pro Comps.
I am doing a rear disc/power brake upgrade on a 78CJ5. I have stockpiled Lincoln Mark VII calipers, newer 7/8 CJ front discs, 8" dual diaphragm booster, corvette type disc/disc 1" master cylinder, disc/disc proportioning valve, and all flex lines are braided stainless. I've read everything I could find on doing the swap but I get conflicting opinions about using the brake booster brake. Some say mount booster directly to firewall, others say the bracket is a must have. I am running a small block stroker with outside the frame Hooker headers which come over top of the steering column so I would prefer not to extend the booster/MC any further forward than necessary. Any suggestions/opinions would be greatly appreciated!!
You should (hopefully) get some faster answers here!
