Brake line question
jeremy5780
1985 CJ7 the proportioning valve has had a small drip for a while so I let it go well the other day it was a puddle so I decided to replace it of course there was a seized bolt and a few brake line nuts seized on, So I had to cut a few lines.After removing the valve I found that the little rubber circle that covers the weep hole had rotted to nothing. So the question I have is the new proportioning valve I have is identical to my old one with one exception my old one has a 3/16 line going to the rear drum brakes. The new proportioning valve looks like it needs a 1/4 line for the rear brake lines. I was just thinking of patching in a short piece of 1/4 to butt up with the 3/16 line what do you think?
