Brake Line Size
Peanut Butter
Full Time Jeeper
- Media
- 37
- Resources
- 1
- Boerne, Texas
- 1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Looks like I'll be able to get back to my CJ7 rebuild after the 1st of the year.
I need to replace all of the brake lines.
The line that runs across the rear axle seems to be smaller than the rest of the lines. What size tubing should I get as I need to replace the entire system. Would stainless steal wrapped brake hose work as well if placed in a protected area.
I'm sure others have bent their own lines, what did you use? Thanks
PS: Power front Disc and Power rear drum is the plan by adding a vacuum booster.
I need to replace all of the brake lines. PS: Power front Disc and Power rear drum is the plan by adding a vacuum booster.
