Electrical Bright lights not working, any thoughts?
totalpackage
Kingston,TN
81 and 79 CJ 5, (sold) , 83 CJ 7 Laredo current
After turning on the light switch, i then press the foot switch and the lights turn off and only the parking lights are on. Press the foot switch again and the normal lights come on. Am i missing something? Is there a common issue that i may need to check?
searching on this will bring you to a lot of people that needed to replace the dimmer switch. they don't hold up well to things that cause corrosion and are often fail because of it
Probably a bad ground. That's what was wrong with mine. Thought it went bad replaced it and same problem. Added a ground wire after cleaning the mounting area and all worked well
Figured i start there and took it out, i assume the dimmer housing must be grounded better, looked like they had rhino lined the floor with that dimmer switch removed and put back in place...but upon spraying switch and receptacle with wd-40, i placed on floor hooked up with alligator jumper on a good ground to housing and pressed and POOF, my grounded jumper burned in half.. . hope my lights are ok, headed to parts store!
The dimmer switch does not use a ground connection. It only switches the +12V from the center pin (coming from the headlight switch) to either the left or right pin to go to the low or the high beam connections. Being bolted to the floorboard, and obtaining any ground connection to the housing, has nothing to do with it. If you burned up your jumper wire, it would seem that perhaps your wire was touching one of the pins that the +12V was on and it created a short circuit. A good working dimmer switch will work fine hanging in the air by the wiring connector. Bolting it to the floor is just to keep it in place so you can press it.
Agree no noticeable difference low vs. high. What type headlamps (original type, halogen, H4 conversions, etc)? Perhaps time for some LEDs.
Work the floor switch a bunch of times to clean the contacts
I saw a YouTube video on that setup. I’m going to check the difference straight from battery on each terminal to verify it’s not the same output for me.
