Can anyone ID this Part?
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
My son removed this part from the inside fender when I wasn't watching and I'm having trouble identifying it, and moreover how do I know if it's any good or working or should it be replaced? Relay switch?
Thanks in advance
Looks like the main computer. Never heard Cj's to have them under the fender though...
I did pull a different part that was much larger, about the size of the jeep radio off of the firewall that I thought was the main computer.
this was on the drivers side fender, and is about the size of a cd case, but thicker.
That is you ignition control module basicl a ford duraspark blue grommet box should have been mounted drivers side on the inner fender
Thanks... any idea of what I should replace it with? or should I replace it?
get an electronic distributor, run a hot wire to it and throw that box away
Davis unified ignition (DUI) makes a good product for around 300 dollars
Skip white performance has one for around 50 dollars
Or make your own 77 nova 250 6 cyl hei dist. And a dist gear From a AMC 304
But for 50 bucks some guys have had pretty good luck with the skip white part.
Or junk yard an hei module and a ford e-core coil from a 90ish ford and use your dizzys mag pickup to trigger it all
As stated, that is your ignition control module, aka the Ford duraspark module. That sends the timing signal to your distributor. The problem is that those specific ICMs are prone to failure, I've gone through three in one year before. The good, they're cheap to replace, and most big box parts store carry them.
You have a few options if you do want to replace it, MSD box, or something similar (I use a Summit Racing brand), or you can go the HEI single wire way. There have been lengthy discussions on this forum debating the merits of either, a quick search of this site will give you TONS of reading options. In the end, it really comes down to personal preference.
