Can't get shift rods out of Dana 20 transfer case
40YearOldCJ
Racine, WI
1977 CJ5, 258, T150, D20, D30, AMC20
Rotate the rod that doesn't have the fork on it 1/4 turn (I don't think it matter which way) and it should tap out fairly easily towards to the front of the case. Be careful when it's almost out because there is a detent ball under spring pressure and it can shoot out when you pull the rod out. I would put a rag over the hole in the front housing above the fork (the one that usually has plastic plugs from the factory) and put another rag in the shift fork hole inside the case. Then you will have room to rotate the other rod to remove the fork.
Here's a great write up with pictures from Billivista: BillaVista.com-Teraflex Dana 20 Transfer Case Rebuild Tech Article by BillaVista
Thanks! I was able to get them out. Seems like it might be fun trying to get them back in with the spring and ball.
Oh it is. I send one flying trying to get them back in.
TCase Dana 20
$35.00
  17.5%
