TCase Transfer case freeze plug?
Transfer case
cthomas
Donator
North Carolina
79 CJ7, 304
I've had my 3 speed manual Transmission rebuild but I'm missing what looks like a freeze plug where the 4x4 shifter linkage goes into the Transfer Case . It was missing before it was rebuilt so I'm not sure if anything goes there. Can anyone advise? Thanks.
Cory
Solution
There are no freeze plugs in a transfer case. Can you snap a picture of what you are questioning? I'm guessing it's a NPT plug. Or, it could be a metal plug. Have you seen my D20 rebuild where you can point out the plug in question?
There are no freeze plugs in a Transfer Case . Can you snap a picture of what you are questioning? I'm guessing it's a NPT plug. Or, it could be a metal plug. Have you seen my Dana 20 rebuild where you can point out the plug in question?
Solution
For some reason I can't upload photos. The first picture of your rebuild it's the two silver plugs above the shifter linkage. One is missing the other is a flat plug.
Thanks!
$20.00
  10.0%
