Carb air leak?
Carb air leak?
Vesuvio
Miami
1981 CJ7
Keep in hearing a hissing sound coming from the carb? What could be? How to detect where it’s coming from, and how to fix it?
Might help for us to know what carb you have.;)
Have you put a wrench to ALL manifold and carb base bolts/nuts?
Make sure you have no loose fitting vacuum lines.
Check the manifold bolts first before you go down the rabbit hole. I had a similar issue and if I done that up front if would have saved me weeks of frustration. I had one bolt a 1/4 turn loose that fixed the problem after wracking my brain and switching out a bunch of parts.
It could be as simple as the butterfly in the throat of the carb making the noise. Have you tried adjusting the idle screw up or down to see if the sound goes away?
If you have the non-electric BBD, then it’s probably just the site going through. If it is, and you slow it down and it idles too low, check your timing. It may be retarded due to wear on parts. Set the idle timing (8 degrees) and then readjust the idle.
