Engine Jeep Soup Oil Leak
Jeep Soup
Donator
Westfield, Wisconsin
1950 CJ-3A (Stock)
1/4 ton Military Trailer (Stock)
2004 Grand Cherokee (set up for expeditions)
Hopefully you get it figured out before your trip. Luckily you have a backup vehicle just in case. :chug:
Yeah I was thinking Suzi Suzuki.
HA !
Suzi Suzuki ......
Funny is that is how the Timber Cruiser got It's camo paint job!!
Previous Owner was my Neighbor's Girlfriend (now wife).
It was White with Pinkish Purple Fenders!!
I would have LOST All My Man Points Driving that around !!
I’m an Insecure Farmer !
I wear a Belt and Suspenders !
Well,
Crown's rear seal DIDN'T WORK !!
It is Leaking BAD !!
So some of the reviews and Videos are Correct.....NFG Chinese Junk.
Jeep Soup is now put in the Back Corner of the Lower Barn until the Winter Lay Up.
I will pull the engine, remove the Crankshaft, and get a Rope Seal to install. Also see how the Clutch Condition is at the same time. It is working fine now, but it would be the Right Time to Replace it.
So Plan B.......
I have brought the Timber Cruiser into the shop to Prep for the "Steve's Adventure Rallye".
I have already changed the Light Bulbs out on the M-416 trailer.
Just have to change the Plug wires for the Turn Signals.
(Jeep Soup has independent Turn Signals, they were added on a separate circuit like many were)
It’s a Jeep. A Jap Jeep.
I will let this thread die out as it is going to be MONTHS before I get at replacing the rear Crankshaft Seal.
I will post the Transmission Wisconsin Adventure Trail Rallye under the appropriate heading.
Wish us Luck and Good Weather.
