Carb Choke wire- '79 CJ5
Wrangled13
Indianapolis
1979 CJ5, 304, completely rebuilding it.
Ok, where does it run to? When I got the CJ (my first CJ) it was already corroded and wrapped around a bunch of other wires. Where is it supposed to run?
There should be an electric choke stat on the passenger side of the carb if Im remembering correctly.
so it runs from the carb to the carb? doesnt seem to make sense to me.
on a side note, get my PM with address? Let me know how much shipping is and we can get this done.
Thansk
Ha just pmed you. I thought there was a wire with a connector that came off the wiring harness and hooked directly into the choke stat to warm the spring inside there expanding it and thus shutting off the choke. Yours is a little older with a V-8 so it may have gone off of tubes that transferred the heat. Can you get any pics? Been awhile since I was around a V-8 powered Cj.
Thansk
heading home now so after I go buy some new hardware I will be in the garage all night and will snap some photos
Thats the best way. Makes it easier if we can see it as well. :notworthy:
