Carb/Distributor Help
MN CJ7
- MN
- 1978 CJ7
Silver paint with black hard top on 33" radials & eagle alumium rims. Good looking ride and have done lots of work to make it look and run great.
Stock equipment is 258 carb, power brakes, power steering, hard top & hard doors (per vehicle gross weight) tilt steering wheel, big brake package with large rotars & drums, T18 Trans with low 6.4 granny gear, Dana 20 transfer, Dana 30 front axle, Dana 44HD rear axle with 3.73 gears. True Trac ft & rear.
I was around jeeps in the 70's and drove a 1973 Jeep Truck. My family had 4 jeeps at the time. We also joined a jeep club back then too. So about 6 years ago looked for a Jeep CJ and found the vehicle above.
Holythat's some good information. I've completely drained the tank and fuel lines and replaced it with new fuel but still having the same problem. I've also removed and cleaned the carb with no improvement. I'm now going to get a timing light and try to figure out how to properly set the timing.
Also, the distributor is an aftermarket DUI if that makes any difference.
Thanks to everyone for their input.![]()
New gas we have a base line.... lets ck a few things...
DUI is a premium after market distributor often known as a HEI... This is a premium version and better than most... The best is the MSD and followed by the DUI. The HEI market has been flooded in past with hardnened gears... Even a few DUIs had them... If you can find TDC #1 using the compression stroke.... might be good idea to ck the gear.... See if you can drill it with a std drill bit like 1/8" and make a little divit... Should drill easily... Hope it passes this test... Then look at the cam gear down the hold and verify it has good shape and all gears there. I think you are OK but this is a good ck on any HEI in AMC.
Any time you work or move distributor mark the mtd collar with a shapie so you can put back in almost the same position... NOT 100% sure with the DUI hei but if pointing to #1 wire location on TDC then the vac advance should be pointing to the front & radiator.
Borrow a time or light or get one, you will need to get this set better.
I still think you have a gas issue...
Once you get it started again..... have small cap of gas, like 2 tablespoons.... This small amt of gas can be put down the carb throat... it this helps the engine run we have a fuel path issue...
When you set up to do this... take air cleaner off. Pump gas 1-2 times fully and watch the choke close.... The choke is closed by a spring.... Electric 12Volts heats this spring and is what opens the choke... it will stay hot 100% of time while the engine is running and hot... Take 2 min for the choke to heat up in summer temps and longer in cold winter months.
Webers Carb.... if the cap of gas helps.
1... Jeep uses a Fuel filter by the carb... Has one input and two out puts... The return line is on top and the carb line is on the bottom... must me mounted this way or you will pump air into carb... To fix just can rotate the filter with lines attached still..
2.... Once when I cleaned a weber during a jet test..... I had a pc of lint catch on the casting.... the linnk worked its way to the bottom of bowl and into the Primary Run Jet the one closest to the choke. When wet the lint was almost clear and could not see it.... Take both run jets out and look for lint.. My lint was stucck in the primary run jet and would not run except on idle and then only some....
3.. I had a weber float stick once on a rough casting and once on the gasket that got crooked.. If the float is held is the up position it will keep gas from filling the bowl... This is one of my lasts guess... i thinks it one of the others...
4.... Do this first...... Webers are very rich.... Pull your spark plugs and write down what each one looks like..... Black sooty wet white and carbonded up.... write down a description for each one... #1 cyliner is by radiator... and #6 is by the firewall.... they should be tan but I am guessing they are black and sooty???? Write down and tell us what you find... If sooty....... clean them off gently with wire brush to remove carbon.... gap them to .045", use copper antizeise on the threads and put them back... Carbon is conductive and can keep the plug from firing..
go thru this ck list and I think you will be running again...
