Was re-reading this and thought about the backfire you said you had with the .031 the first time you ran it...One of the tuning problems people have is changing more than 1 thing at a time before road testing. The smartest, although slowest, way of tuning is to do it (road-test) after each mod you make...no matter how simple it seems.
I'm not sure why you are considering going back to the .031
but make sure that with each squirter you try, you road test from a dead stop, and then from a 20-30 mph roll. THEN change the cam screw to the other hole, do it all over BEFORE you decide the squirter is wrong for the setup...
The reason has to do with both the fuel curve on the cam and the delivery rate of the squirter. You have to test them out in combinations to find one that will have punch off the crawl and not bog while driving...IF, after those four trials the motor bogs or backfires from a dead stop or bogs in the roling midrange and none of those combinations work...you now know the squirter is wrong.
