Carb question
Carb question
mcraig8860
Fleming Island, FL
'85 CJ7, original 6 clyinder (rebuilt), 4 speed with original trans case and diffs.
I have a '85 CJ7 and the original Carter 2 bbl had been replaced with a Weber 2 bbl. When the conversion was made the throttle cable was moved from the driver's side of the carb to the passenger side of the card. The Weber is now not working properly and is no longer made nor do the make a rebuild kit for it. I have purchased a new Weber 2 bbl (Kit K551) and it requires the throttle cable to be back on the driver's side of the carb. Anyone out there have an original bracket from the Carter carb or know where I can get one.
When I bought my Jeep it had a weber on it, any chance you have a pic of what you need ? I might have it attached to the old carb.
