carrier damage
carrier damage
82Scrambled
new jersey
1982 CJ-8 456 gears, ARB Air Lockers F&R, T-4 trans Dana 300
Where is BUSADAVE??? :D
I am no ARB expert and may be missing something. But pretty much all I can tell is that you are trying to get a pattern?
I run the same set up, ARB, 4.56 gears. The wear pattern looks like the pinion depth is set to deep to me.
no guys thats rust from sitting for 3 years without more than a 1/2 cup of oil :mad:
its the carrier, i think the PO blew out a pinion bearing and it [pinion gear] fell into the carrier. what do u think??
It might be best then to take it apart and inspect bearings and pinion, to be sure.
I wouldn't worry about the carrier. That seems to be fine. If the pinion bearing went out it could damage the ring and pinion gears. Then during the repair you want to make sure the PO set up the gears properly.
I would look over the ring and pinion.
I see marks on the carrier. Your pinion has to be loose.
Thanks, it's Sublime from 2008 Dodge Charger. I like yours too. There's something about bright-<-BAD WORD-> green that just says "HELLO"
i agree with you . its a love hate type of color. mine 1970 mopar sassy grass green
Yep. My 401 is Grabber Green...you either love it or you hate it :D
$125.00
  62.5%
