Carter 6736 fuel pump install on AMC 360
Deerejeep
- Bettendorf IA
- '81 CJ7 4 cyl. S4, d300 soon to be amc360 t18 D300. Restoration.
'08 JK 4" lift, 35" and on and on.
Okay folks this should be simple, I've watched a YouTube video or two and simple enough. You angle it up a bit, little pressure from the spring and it's on. When i tried it, it does not want to go in straight and it's like I need to tighten down the firewall side bolt to get it in parallel. Should I just apply a little force to it or be careful? Any thoughts?
