Carter Carb Rebuild, Throttle Body Gasket Question
queuemay
- Atlanta, Ga
- 1974 CJ5, AMC 258 I6. Stock everything as far as I can tell.
I've completely dismantled and cleaned my Carter YF (a?) 7039S carb, and am about to put it all back together. I've got the rebuild gasket kit for my model #. Looking at the gaskets that came off, I noticed a few holes were covered over the throttle body manifold, see the images below, I point to the ones that are covered by the gasket. Is this normal or was the wrong gasket used previously?
Thanks!
Thanks!
, and timing needs to be adjusted as well, but I figured I'd start here. The symptoms kind of overlap, but, one step at a time.
