Challenge Question: What is leaking and how do I fix it???
65reissue
- Media
- 6
- Alpena, AR
- 77 Jeep CJ5 - Renegade - 304 w/3 spd - pretty stock at the moment.
Hey guys...from the pictures I attached, can you tell what is actually leaking from the steering box and what do I need to do to fix it? ...replace? ...rebuild? thanks for any help you can lend.
but if it is the box I say get a new one or a rebuilt.Thanks guys...I'll clean it up and see what I'm dealing with but from looking at it, i don't think its coming from above the box. Is a rebuild something that needs to be tackled by someone pretty experienced? Or should I possibly look for a rebuilt? thanks again for your help.
65
That is what I thought also, but pictures are deceiving. I just did not see any indication of the oil coming from above on your fan shroud or bottom pulley just looked like that front high pressure seal leaking to me.
In regards to you doing it............not impossible but that seal is delicate and in a tough place to get out even if you remove the gear without the proper tools not withstanding keeping away from the sealing surface on the shaft during that seal removal process...........if the shaft has a groove in it from wear a new seal will do you no good anyway...........Your call?
Those gears I believe are only around $150-$175 or so at Napa or check on line.
