Changing from the stock Alternator to 150Amp Alternator
I guess depends on why you need that much or what you plan to be doing. I use my rig mostly for camping, beach and hunting - when not commuting on weekdays (mine is a daily driver in Houston). So I am using an inverter, front spot lights, OBA for beach toys or camping air mattress, etc. When I did the engine swap, I opted for the serpentine belt kit that came with a new P/S pump, AC compressor, and 105 amp GM alternator. Since I use power when the engine is not running (no alternator output), I added a second battery for these needs. That way if I drain the secondary battery too low at the camp site, I can still start the engine from the untouched primary battery. High amp alternator output didn't fit my needs - a secondary power source protecting my main starting battery was a better choice for me.Great answer, thank you for the comprehensive information. Now all I have to do is justify the price to myself.![]()
