Chewed the camshaft gear...
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Well it happened... My DUI distributor swap apparently was not thought out as far as I thought.
I assumed the info Summit gave me was correct, and the info I had seen was correct, but my AMC 304 V8 did apparently have a soft gear and DUI a hard gear.
I ran this set up for 7 months... But during my trip last week to the Rubicon, it finally died. Confirmed the camshaft gear is chewed...
So I found new gear sets (distributor and camshaft) Omix-Ada 17423.03 - Omix-Ada Distributor Drive Gear Kits - Overview - SummitRacing.com now just wondering what i should do.
Planning to drop the oil pan, check everything out, put a magnet in there, check and flush the oil pump, check out the timing chain while there, pull the heads off and look at the cylinder walls and lifters / rods...
Am I going overboard or does this all sound reasonable?
Anything else I should check?
I did make it a ways through the Rubicon trail though, so trip report and pics in the next few days...
~ JR
~ JR
