Choke Thermostat Tube Name
kim
Miami
CJ7, 268 I6
You're right, it's called a heat tube. I've never found another one specifically for the AMC 258 i6 / 4.2l either. I doubt like heck you could get it out either, it's copper, it's soft enough you should be able to bend it back in to shape.
I can say, that I've never had one hooked up to any of the Motorcraft/Autolite carbs that I've ran, and I've never had an issue with the choke working correctly. If you want one, I've found a couple places that sell them, you'll just have to make it work to the AMC 258 / MC2100 set up.
Choke Heat Tubes
Engine - Choke-Heat Riser Tubes & Related Parts
https://www.amazon.com/Dorman-55111-HELP-Choke-Stove/dp/B001HZKEPS
https://www.amazon.com/Dorman-HELP-76850-Choke-Heater/dp/B000CO96U4
    Best for votes
    on specific items
$35.00
  17.5%
